Change Cron settings from script - Printable Version
+--- Thread: Change Cron settings from script (/showthread.php?tid=62)
Change Cron settings from script - RSV4 - 13.08.2015
Hi all,
is it possible to edit the cron settings of a script from another script? Reason is I'd like the end-user to choose when certain scripts are executed.
Best regards,
Robin
RE: Change Cron settings from script - Pawel - 13.08.2015
it's posibble to enable/disable one script form another.
script.disable(name_of script) - it disable script named "name_of script". i assumed that "script.enable()", enables script
RE: Change Cron settings from script - RSV4 - 14.08.2015
Can I change the time and weekdays of a scheduled script from another script?
RE: Change Cron settings from script - Pawel - 16.08.2015
http://openrb.com/example-change-the-scheduled-program-time-parameters-dynamically-from-visualization/
RE: Change Cron settings from script - RSV4 - 16.08.2015
Thank you! :-)
