How to Display 1-bit Object in New Visu + Change Shape Border Color via JavaScript - Printable Version
+--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24)
+--- Thread: How to Display 1-bit Object in New Visu + Change Shape Border Color via JavaScript (/showthread.php?tid=6211)
How to Display 1-bit Object in New Visu + Change Shape Border Color via JavaScript - Fahd - 10.12.2025
Hi guys,
I’m working with the new Visu, and I’m struggling to understand how to display a 1-bit object.
Also, if possible, I need some help controlling the border color of the Shape widget using JavaScript. I want the border to turn green when the object at 32/1/6 is true, and red when it is false.
Screenshot attached.
RE: How to Display 1-bit Object in New Visu + Change Shape Border Color via JavaScript - Fahd - 11.12.2025
(10.12.2025, 18:47)Fahd Wrote: Hi guys,
I I figured out how to display  the 1bit ibject with choose switch widget and make it read only (big brain moment ...)
RE: How to Display 1-bit Object in New Visu + Change Shape Border Color via JavaScript - admin - 11.12.2025
To add a border depending on the switch value:
In Switch widget appearance set Additional CSS classes to switch-border
Add to Custom CSS:
.switch-border[data-value="true"] .compactmode {   border: 1px green solid; } .switch-border[data-value="false"] .compactmode {   border: 1px red solid; }
