Alexa Skill Sync - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Alexa Skill Sync (/showthread.php?tid=6216) |
Alexa Skill Sync - didac - 12.12.2025 Good morning, I created a new skill in Alexa, clicked sync, and it synced without error (the current time is displayed). The problem is that the new skill doesn't appear in the Alexa app. Is there any way to force the sync in the Alexa app? What do I need to do to make it appear? Thank you RE: Alexa Skill Sync - Daniel - 12.12.2025 Alexa, discover. RE: Alexa Skill Sync - didac - 12.12.2025 (12.12.2025, 09:23)Daniel Wrote: Alexa, discover. We've done that and it's not showing up. We've also tried "Alexa, discover new devices" and it's not finding the new skill. What else can I try? RE: Alexa Skill Sync - Daniel - 12.12.2025 Works for me, how do you know it is not discovered? RE: Alexa Skill Sync - didac - 12.12.2025 (12.12.2025, 10:50)Daniel Wrote: Works for me, how do you know it is not discovered? I added a new device with its skills (in LM). I sent the "Discover" command, but the new device isn't showing up in Alexa's device list. RE: Alexa Skill Sync - Daniel - 12.12.2025 Check logs in LM cloud app. RE: Alexa Skill Sync - didac - 12.12.2025 (12.12.2025, 10:57)Daniel Wrote: Check logs in LM cloud app. The latest LM Cloud App record about Alexa "2025.12.12 10:01:35 config sync finished for alexa (17733) " I give Alexa the command "Discover new devices," and it seems to be thinking for a long time, but it's like it freezes and doesn't find any new devices. It can be thinking for up to 5 minutes. Is this normal? RE: Alexa Skill Sync - Daniel - 12.12.2025 It take a while but it does it much faster for me, 2min or so. What type of device are you trying to add? RE: Alexa Skill Sync - didac - 12.12.2025 (12.12.2025, 11:20)Daniel Wrote: It take a while but it does it much faster for me, 2min or so. What type of device are you trying to add? I'm trying to add a dimmable light with brightness and power control. I have others just like it and they work. RE: Alexa Skill Sync - Daniel - 12.12.2025 Just tried device with brightness and power stare, discovered as normal. Not sure what to suggest. Did you assign all objects? RE: Alexa Skill Sync - didac - 12.12.2025 (12.12.2025, 11:30)Daniel Wrote: Just tried device with brightness and power stare, discovered as normal. Not sure what to suggest. Did you assign all objects? Solved! It seems it was an Alexa problem. I logged out and back in with my phone, and then it appeared. I don't understand anything. A reset always fixes everything. Thanks |
