Connection between 2 LogicMachines - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Connection between 2 LogicMachines (/showthread.php?tid=6217) |
Connection between 2 LogicMachines - Chandrias - 13.12.2025 I have 1 LM on my office and 1 on my house. Is it possible to create a connection between them and exchange information? I would like to get some readings and even be able to send a command if required. RE: Connection between 2 LogicMachines - admin - 13.12.2025 One of many solutions: https://kb.logicmachine.net/integration/mqtt-cloud/ RE: Connection between 2 LogicMachines - Chandrias - 13.12.2025 (13.12.2025, 08:06)admin Wrote: One of many solutions: https://kb.logicmachine.net/integration/mqtt-cloud/ So, If I understand well, you will need an intermediate Cloud service to bridge the communication. Isn't there an option for direct communication between the LM's? RE: Connection between 2 LogicMachines - Novodk - 13.12.2025 Admin, correct me if I'm wrong. Instead of an external MQTT broker, I guess you could use the built in broker on one of your LM. Connect both LM to the same ZeroTier network. RE: Connection between 2 LogicMachines - Chandrias - 13.12.2025 (13.12.2025, 11:13)Novodk Wrote: Admin, correct me if I'm wrong. I am new to this area, so forgiver my ignorance. I already have a VPN connection between my home and my offfice. (If that helps) Is there a manual on how to implement the configuration between the two devices? RE: Connection between 2 LogicMachines - admin - 13.12.2025 Yes, ZeroTier is another option. If both LMs can already reach each other over VPN then you can run MQTT broker on one LM and use the same approach as mentioned in our knowledge base but with a local server. RE: Connection between 2 LogicMachines - Chandrias - 06.01.2026 (13.12.2025, 11:43)admin Wrote: Yes, ZeroTier is another option. I have never approached that issue. Do you have a detailed guide on how to implement it? RE: Connection between 2 LogicMachines - admin - 06.01.2026 Install and configure MQTT server (broker) on one LM: https://kb.logicmachine.net/integration/mqtt-server/ Then follow this guide starting from #3: https://kb.logicmachine.net/integration/mqtt-cloud/#3-set-up-mqtt-private-cloud-connector-for-each-logicmachine RE: Connection between 2 LogicMachines - Chandrias - 09.01.2026 (06.01.2026, 11:50)admin Wrote: Install and configure MQTT server (broker) on one LM: https://kb.logicmachine.net/integration/mqtt-server/ On both my servers there is no option for input/output tag "mqtt". See attached picture RE: Connection between 2 LogicMachines - admin - 09.01.2026 You need to assign this tag to objects first. RE: Connection between 2 LogicMachines - Chandrias - 09.01.2026 (09.01.2026, 09:24)admin Wrote: You need to assign this tag to objects first. And how do you do that? RE: Connection between 2 LogicMachines - Daniel - 09.01.2026 Go to LogicMachine object tab and click on it and add TAG. You can also use filter and Mass edit to do many at once. RE: Connection between 2 LogicMachines - Chandrias - 09.01.2026 (09.01.2026, 11:57)Chandrias Wrote:(09.01.2026, 09:24)admin Wrote: You need to assign this tag to objects first. I figured it out. Thanks |
