zigbee rs232 coordinator error - Printable Version
+--- Thread: zigbee rs232 coordinator error (/showthread.php?tid=6225)
zigbee rs232 coordinator error - tigi - 17.12.2025
I've got a problem with a zigbee rs232 coordinator not coming up, worked without problems till today.
Restarted the logicmachine, checked connections and reset power to zigbee rs232 coordinator but with no result.
Below is the log I get:
2025-12-17 23:03:04 ZNP: sending request: [6] FE 01 41 00 01 41 2025-12-17 23:03:04 CC: sending AREQ_SYS_RESET_REQ, data: { Type = 1 } 2025-12-17 23:03:04 CC: resetting device 2025-12-17 23:02:44 ZNP: sending request: [6] FE 01 41 00 01 41 2025-12-17 23:02:44 CC: sending AREQ_SYS_RESET_REQ, data: { Type = 1 } 2025-12-17 22:55:05    CC: resetting device 2025-12-17 22:54:45    CC: resetting device 2025-12-17 22:54:25    CC: resetting device 2025-12-17 22:54:24    CC: init /dev/RS232 2025-12-17 22:54:11    TASK initialize aborted: stack traceback: [C]: in function 'assert' ...tmp.G9yFHxwEAJ/files/store/daemon/zigbee/zigbee/core.lua:979: in function <...tmp.G9yFHxwEAJ/files/store/daemon/zigbee/zigbee/core.lua:975> 2025-12-17 22:54:11    ZB: could not start coordinator 2025-12-17 22:54:11    CC: error initializing 2025-12-17 22:54:11    CC: could not reset dongle 2025-12-17 22:53:51    CC: resetting device 2025-12-17 22:53:31    CC: resetting device 2025-12-17 22:53:11    CC: resetting device 2025-12-17 22:53:10    CC: init /dev/RS232
Does this mean the zigbee rs232 is defective and needs to be replaced or is this another problem?
Greetings,
Tigi
RE: zigbee rs232 coordinator error - Daniel - 18.12.2025
What are the LEDs saying? Check wiring just in case.
RE: zigbee rs232 coordinator error - tigi - 18.12.2025
(18.12.2025, 08:29)Daniel Wrote: What are the LEDs saying?  Check wiring just in case.
Hi Daniel,
On the zigbee rs232 the 2 leds are on, one green for net and one red for power.
The logicmachine has one green led blinking, beside a constant on yellow led for poe.
I also see a red light blinking at the same rate from inside the logicmachine housing at the side of the rs232 ports.
Greetz.
Tig
Hi Daniel,
Greetz.
Tig
Problem solved!
Didn't do much apart from checking the wires again,I assume it was a bad contact.
After reboot the device is working properly again.
Thanks for the assistance!
Greetz,
Tigi
