dynamic name for a table - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: dynamic name for a table (/showthread.php?tid=6228) |
dynamic name for a table - CristianAgata - 21.12.2025 Good morning, I need a suggest how do this: I would like create some tables but the names must be dynamic, I will try to explain better with an example. my_table = {} for i = 1, 10,1 do (here i need to create 10 new tables) end the result I would like have could be this my_table_1, my_table_2, my_table_3,... my_table_10. I wish to explain myself. BR Cristian RE: dynamic name for a table - admin - 21.12.2025 Create a table with tables inside of each key
RE: dynamic name for a table - CristianAgata - 21.12.2025 (21.12.2025, 11:07)admin Wrote: Create a table with tables inside of each key Thanks admin, Could be a solution, sorry but I'm a little bit confused ?. Can you share an example? BR Cristian RE: dynamic name for a table - admin - 21.12.2025 Code: t = {}
for i = 1, 10 do
t[ i ] = {}
log(t[ 2 ])RE: dynamic name for a table - CristianAgata - 21.12.2025 (21.12.2025, 11:37)admin Wrote: Thanks but I don't explain myself very well, this my situation: I have name = {'Tv_1','Tv_2','Tv_3'} number_entry = 3 entry = {[1] = {['component'] = 'switch'}, [2] = {['component'] = 'audioVolume'}, [3] = {['component'] = 'audioMute'}} result must be a table as this: new = {{[Tv_1] = {['component'] = 'switch',['component'] = 'audioVolume',['component'] = 'audioMute'}, [Tv_2] = {['component'] = 'switch',['component'] = 'audioVolume',['component'] = 'audioMute'}, [Tv_3] = {['component'] = 'switch',['component'] = 'audioVolume',['component'] = 'audioMute'}} in this way in a second part of script when I will call object = new.Tv_1[1] I will give switch Best regards Cristian RE: dynamic name for a table - CristianAgata - 21.12.2025 (21.12.2025, 13:13)CristianAgata Wrote:Hi, after several test I have found this solution. Do you think could works?(21.12.2025, 11:37)admin Wrote: Code: name = {'Tv_1','Tv_2','Tv_3'}
new_t = {}
for _,value in ipairs(name) do
new_t[value] = {}
table.insert(new_t[value], entry)
--storage.set('my_new_table', new_t)
log(new_t['Tv_1'][1][1])RE: dynamic name for a table - admin - 23.12.2025 If you get the result you want then it's fine. Not sure if you need another table (new_t['Tv_1'][1][1]), it might be enough just to do this: Code: for _,value in ipairs(name) do
new_t[value] = entry
log(new_t['Tv_1'][1]) |
