Rotate Function in New Visu Severely Distorts Objects and Bounding Box - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Rotate Function in New Visu Severely Distorts Objects and Bounding Box (/showthread.php?tid=6235) |
Rotate Function in New Visu Severely Distorts Objects and Bounding Box - savaskorkmaz - 03.01.2026 Hi, While working with the new Visu graphical editor, I noticed a serious issue with the rotate function applied to objects/icons. You can see the problem clearly in the attached screenshot:
a note : rotate 45 degree CSS code is working wery well. But we don't want to use CSS for every rotate degree. Can you make your rotate function like css ? RE: Rotate Function in New Visu Severely Distorts Objects and Bounding Box - Daniel - 05.01.2026 Rotate function will work correctly only on a square elements, make your custom icon square with the element in the middle. RE: Rotate Function in New Visu Severely Distorts Objects and Bounding Box - savaskorkmaz - 05.01.2026 Hi , in modern scada systems we almost don't have any square elements. Many fans, pipes %90 of the elements are not square. We require it will work like CSS code which is working as now. .rot45 { transform: rotate(45deg); } |
