Additional Icons Do Not Trigger at Exact Range Boundary Values - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Additional Icons Do Not Trigger at Exact Range Boundary Values (/showthread.php?tid=6236) |
Additional Icons Do Not Trigger at Exact Range Boundary Values - savaskorkmaz - 03.01.2026 Hi, In the new Visu graphic editor, there seems to be an issue with the Additional Icons value range handling. I created range intervals as shown in the screenshot (0–10, 11–20, 21–30, etc.). However, the icons are not triggered when the object value is exactly equal to the range boundary values such as: 10,20,30,40,50,60,70,80,90. Instead, the icon only works when the value is inside the range but not at the boundary, for example: 11, 21, 32, 41, 55, 67, 72, 82, 92 This behavior was not present in the old Additional Icons system — in the previous version, intermediate and boundary values worked correctly. So currently the range logic behaves like:
This looks like a bug in the new editor. Could you please check? Thanks. RE: Additional Icons Do Not Trigger at Exact Range Boundary Values - stianj - 28.01.2026 I have noticed this as well, and was happy when this question was asked. But does no reply mean that it is by design..? RE: Additional Icons Do Not Trigger at Exact Range Boundary Values - admin - 28.01.2026 This will be reworked in the upcoming version. Value matching rules: Min ≤ Value ≤ Max or Value = Min if Max is not set Matching will be done in reverse order. So if your ranges overlap (previous max = next min) then the latter will be used. RE: Additional Icons Do Not Trigger at Exact Range Boundary Values - stianj - 28.01.2026 Thank you! Looking forward to the next version, seems to be a lot of nice improvements!
