Trend widget Y-axis - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Trend widget Y-axis (/showthread.php?tid=6258) |
Trend widget Y-axis - Fahd - 19.01.2026 Hi, I noticed a small issue with the Trend widget. The values on the Y-axis are not displayed with the decimal separator (,) and it is not possible to adjust the number of decimal places for the parameters. As a result, when hovering over the trend to read recent values, the values appear as 195 and 1925 instead of 19.5 and 19.25, as shown in the attached screenshot. RE: Trend widget Y-axis - Daniel - 19.01.2026 Can you drop a screenshot of a actual tool-tip? It works for me correct. What settings did you use for this trend in LM trend tab? RE: Trend widget Y-axis - Fahd - 19.01.2026 (19.01.2026, 09:24)Daniel Wrote: Can you drop a screenshot of a actual tool-tip? It works for me correct. What settings did you use for this trend in LM trend tab? Now its woriking fine... |
