Adding camera on Visu app - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Adding camera on Visu app (/showthread.php?tid=6268) |
Adding camera on Visu app - Chandrias - 24.01.2026 Sorry if you already discussed the mater, but I could not find any guidance on it. I have an IP camera (HIKVISION), which i would like to see on my Visu app. I can access the camera through any browser, but when I add it in Visu, I don't get any picture. Any idea on what might be wrong? RE: Adding camera on Visu app - CristianAgata - 24.01.2026 (24.01.2026, 11:29)Chandrias Wrote: Sorry if you already discussed the mater, but I could not find any guidance on it. Good evening, Can you show the http string are you using? Best regards Cristian RE: Adding camera on Visu app - Chandrias - 25.01.2026 (24.01.2026, 14:55)CristianAgata Wrote:(24.01.2026, 11:29)Chandrias Wrote: Sorry if you already discussed the mater, but I could not find any guidance on it. I tried a few, but with no success. This (http://192.168.99.182/doc/page/preview.asp) is the one I use to access the camera through my browser RE: Adding camera on Visu app - CristianAgata - 25.01.2026 (25.01.2026, 12:13)Chandrias Wrote:(24.01.2026, 14:55)CristianAgata Wrote:(24.01.2026, 11:29)Chandrias Wrote: Sorry if you already discussed the mater, but I could not find any guidance on it. Hi, Try thisĀ http://<up cam>:<port>/ISAPI/Streaming/channels/101/picture Set proxy with your credentials and refresh every 1 sec Best regards Cristian RE: Adding camera on Visu app - AlexLV - 25.01.2026 Hi, working for me: http://IP/ISAPI/Streaming/channels/102/picture?videoResolutionWidth=640&videoResolutionHeight=320 Resolution should be provided and checked, some HIK cameras not showing stream without resolution in link. Moments to check: 1. Just not remember, but I think for stream you want to use - MJPEG coding should be used. In my link - 102 means 2nd stream, so check settings for camera's 2nd stream; 2. Select mark "Request snapshot using local proxy and put login and pass for stream you want to use"; 3. Put refresh rate not less than 5 seconds. Some time is needed to create picture, some to send it. This is just snapshots and not works in real time. Not forget about load to network/proxy/cloud etc..; 4. Check size of the snapshot - admin told me it should not be over than 1 Mb (Just open picture from visu in new window and save it, check size). At one site I have new 4 MP HIK cameras and some problems because of snapshot is over 1Mb but customer locally need both streams with max quality.. Alex RE: Adding camera on Visu app - Chandrias - 26.01.2026 (25.01.2026, 13:21)CristianAgata Wrote:(25.01.2026, 12:13)Chandrias Wrote:(24.01.2026, 14:55)CristianAgata Wrote:(24.01.2026, 11:29)Chandrias Wrote: Sorry if you already discussed the mater, but I could not find any guidance on it. The new link works just fine. Thank you. |
