Gateway to Crestron - Printable Version
+--- Thread: Gateway to Crestron (/showthread.php?tid=627)
Gateway to Crestron - Brillebjørn - 17.02.2017
Has anybody succesfully set up a connection from KNX-bus to Crestron-processor through an LM4? If so, how is this done?
Regards
Bjørn
RE: Gateway to Crestron - mlaudren - 20.02.2017
Crestron use a proprietary protocol.
And they have gateway to other protocols like cresnet-KNX, crestnet-modbus, ...
You could use a crestnet-knx gateway for this. our maybe by ethernet, but I'm not sure you have an open API on the processor...
RE: Gateway to Crestron - Arnts - 21.02.2017
(20.02.2017, 18:34)mlaudren Wrote: Hi,
The point here was to use LM4 as a Crestron --> KNX gw, so that you don`t have to buy both :Smile
So make a connection from Crestron to LM via TCP/IP and read/write to Groupadresses in KNX.
Has this been done?
RE: Gateway to Crestron - edgars - 22.02.2017
I have heard that somebody from our partner's customers has done this type of integration over TCP client/server. I have requested if its possible to send us this work for public sharing. Will update here once and if I have it.
RE: Gateway to Crestron - mlaudren - 22.02.2017
Has this been done?
Didn't understand it properly...
I thought the goal was to control Crestron device from LM.
If it's to control knx From the Crestron processor (trough LM), yes, using the remote API will work fine, or as said by Arnts TCP connection.
RE: Gateway to Crestron - nibelong - 04.03.2017
You can make the connection between Crestron and LM using example of the site.
http://openrb.com/example-lm2-as-tcp-server-for-external-requests/.
You need to come up with a data transfer protocol between the Creston and LM. I have used in this message format - “function_groupadress_value”:
- “function”- name function (switch, temp, dimm)
- Groupadress - Group address bus KNX
- Value - the value for the group address
This message must be disassembling in LM.
Detail of script code
--function_ groupadress_value
dim_check = string.split(data, '_')
--диммирование освещении
if (dim_check[1] == 'dimm' || dim_check[1] == 'temp'|| dim_check[1] == 'switch') then
value = tonumber(dim_check[3])
grp.write(dim_check[2], value)
The response from the LMA in Crestron is forming similarly to the example online.
Event-based program
Event-based script will monitor the object ‘1/1/1’, if it is switched on, “Lamp is ON” is sent to all TCP clients currently connected to Logic Machine 2 TCP server, if lamp is switched off – “Lamp is OFF”.
Source code
1. value = knxdatatype.decode(event.datahex, dt.bool)
2. udpsend('Lamp is' .. (value and 'ON' or 'OFF'))
Crestron connects with the LMA through the unit "TCP/IP client". You must specify the correct port and IP-address of the LM.
I think there will not be problems with sending commands and parsing response from LM.
RE: Gateway to Crestron - s.prathmesh - 28.12.2017
Checked the mentioned steps. It seems, that is working for getting the status of KNX GAs.
Here, how can we control KNX GAs from Crestron with TCP/IP?
