Modbus write multiple registers - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus write multiple registers (/showthread.php?tid=628) |
Modbus write multiple registers - Alferov - 17.02.2017 Hello! fw 20160927 Modbus Code: if not mb then
mbproxy = require('mbproxy')
mb = mbproxy.new()
mb:setslave(4)
res, err = mb:writemultipleregisters(46165, o1, o2, o3)
if err then log(err); endQuote:Logs: *string: Illegal function What not so? RE: Modbus write multiple registers - admin - 17.02.2017 This is a reply from the slave telling that this function is not supported. Actually, writemultipleregisters only make sense when writing one register to a device which only supports function code 16. With multiple registers writemultipleregisters and writeregisters are identical. Try using writeregisters and write only one register at a time. RE: Modbus write multiple registers - Alferov - 17.02.2017 In a manual on the device it is written what can be written in this address only through function 16. I tried writeregisters - too an error: Illegal data! p.s. this device - http://bolid.ru/files/373/566/s2_pp_v124_modbus_only_e.pdf RE: Modbus write multiple registers - Erwin van der Zwart - 17.02.2017 Hi, Do you have jumper XP1 set to master mode? Writing to multiple register starting at 46165 is only possible when device is master according to manual. BR, Erwin |
