Script from specific part of a 6-byte? - Printable Version
+--- Thread: Script from specific part of a 6-byte? (/showthread.php?tid=6299)
Script from specific part of a 6-byte? - TobiasA - 11.02.2026
Hello!
I want to create a script that reads/checks a few groupadresses that are 6-byte and only look for a specific part of the 6-byte and if that part is '30'.
Then make an OR-gate that asks if any of my groupadresses shows 30 in the specific byte [6] send out true to a new groupadress else false.
See attached pictures. In logicmachine it is recorded as 'LTRF 3'. And in KNX it is shown as '30'.
Either a persistant script or I need the 6-byte adresses to start the other script that checks for the right byte.
I have tried for a while but cant come up with a solution!
Hope you understand my question.
Thanks for any help.  Smile
Best regards,
Tobias
RE: Script from specific part of a 6-byte? - admin - 11.02.2026
Add dalitest tag to all DALI test result group addresses. Create an event script, attach it to dalitest tag. Change 1/1/1 to your error status group address. Make sure that error status address is not tagged.
objects = grp.tag('dalitest') err = false for _, object in ipairs(objects) do   ltrf = object.value.ltrf   if ltrf == 3 or ltrf == 4 then     err = true     break   end end grp.checkupdate('1/1/1', err)
RE: Script from specific part of a 6-byte? - TobiasA - 12.02.2026
Thanks for the help so far!
I cant get the event script to start. I see my dali-statuses coming in but my scrift wont activate.
What have I done wrong? See attached pictures.
Best regards,
Tobias
RE: Script from specific part of a 6-byte? - admin - 12.02.2026
Your event script is not attached to a tag. Go to Scripting > Event-based. Click the relevant script and select the correct tag in "Group address / tag" field.
I see, I did that now. Didnt know how to "attach a tag". Thanks alot.
But sadly I still dont see a reaction in my script when my dali-statuses activates and are tagged to my script.
For the status object to change at least on of the test results must report an error.
Ofcourse! I thought I would get an update even if no one showed an error. But I tested again with an error and it works, the scripts sends an error (true) and when I then remove the error the scripts sends false.
Seems to be working like I want.
Thanks so much for your time and help! You saved me.
