Function 23 with modbus RTU ? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Function 23 with modbus RTU ? (/showthread.php?tid=63) |
Function 23 with modbus RTU ? - mgena - 14.08.2015 Hello, I have an equipment to connect which only supports function code 23 using modbus RTU (read/write multiple values). Is it possible to communicate with this function code ? Using a script or directly sending frames to the RS435 port ? Thanks, RE: Function 23 with modbus RTU ? - admin - 18.08.2015 We will implement this in the following firmware release. |
