custom values in visu - Printable Version
+--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24)
+--- Thread: custom values in visu (/showthread.php?tid=6306)
custom values in visu - toujour - 16.02.2026
what is the better way to see the custom values in new Visu ? (I see the number value and not the custom )
Alberto
RE: custom values in visu - Daniel - 16.02.2026
Additional values/icons in Visu is the same what Custom values are LM. If you set a object on the witget you will be able to load custom values to visu if they are set.
RE: custom values in visu - toujour - 18.02.2026
Now I undertand
I must change it here
and not here
RE: custom values in visu - Daniel - 18.02.2026
As I mentioned above, if you define them under objects, you can load them to visu widget but first you must select the object in visu widget.
