Geofencing/-tracing as "Home"-indicator - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Geofencing/-tracing as "Home"-indicator (/showthread.php?tid=6307) |
Geofencing/-tracing as "Home"-indicator - PolymorphedCust - 17.02.2026 Hi I'd like to have a bit in my system for when me and/or my girlfriend is home. This will be used to enable/disable alerts on my windows/door magnets, to alert for theft etc. I've tried to play around with Googles API and the Traccar which was previously used in the docs, but my skills/experience is not extend enough for me to make this work. Can anyone lead me in the right direction of scripting this with a API or something. I have a Google Pixel phone and my girlfriend has an iPhone, so it should be able to work with both of these types of phone. I also tried making a bool for Google Home Assistant and use the internal Google "enter/leave location", but it is too non responsive. I do not care with the constant location of my and my girlfriend's phone, but just if i come home and leave home. Thanks in advance. RE: Geofencing/-tracing as "Home"-indicator - admin - 17.02.2026 You can use Wi-Fi registration table from your router as a presence indicator. Here's a solution for MikroTik routers: https://kb.logicmachine.net/integration/mikrotik/#example RE: Geofencing/-tracing as "Home"-indicator - PolymorphedCust - 17.02.2026 Thanks a lot. So the easiest way will be; If I have a dumb provider-sent router, change this to a more intellect router and set it up here? Meanwhile I find such, is there another easy workaround? |
