Switch widget with 0 value - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Switch widget with 0 value (/showthread.php?tid=6315) |
Switch widget with 0 value - Frank68 - 18.02.2026 Hello I was migrating a project to the new view, and I have a small problem. I need to set an object representation that is tied to a bit. If the bit is at 0, I shouldn't see anything; if the bit is at 1, I should see a colored rectangle. The problem is that when I use the switch widget with the value at 0, it turns blue as if it were active. It's a read-only object. What am I doing wrong? Thanks RE: Switch widget with 0 value - admin - 18.02.2026 1. Set Additional CSS classes to hide-when-false 2. Add to Custom CSS: Code: .user-view .hide-when-false[data-value=false] {
display: none;
}This will completely hide the widget in user view when the value is false. RE: Switch widget with 0 value - Frank68 - 18.02.2026 (18.02.2026, 12:15)admin Wrote: 1. Set Additional CSS classes to hide-when-false ok I add this code in custom CSS, for use this code need to wirte in appearance in additional CSS hide-when-false ? Thanks RE: Switch widget with 0 value - Daniel - 18.02.2026 Yes the additinal classes are added in widget apperance on the bottom. |
