Hide visual objects in the display - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Hide visual objects in the display (/showthread.php?tid=6318) |
Hide visual objects in the display - ALEJANDRO - 19.02.2026 I'm not sure if I'm posting this question in the right section, but I'll ask anyway. I've created a screen that uses visual icons to display alarms. I've attached an image. When the object representing the alarm is ON (1), a red alarm should appear, like the one in the image. The problem I'm having is that when the object is OFF (0), I don't want a different colored icon to appear. I simply want the alarm to be hidden, and I don't know how to do that without CSS or Lua scripting. Is there any way to do this? Thank you very much. RE: Hide visual objects in the display - admin - 19.02.2026 You can use a fully transparent image as an icon. RE: Hide visual objects in the display - ALEJANDRO - 19.02.2026 You are totally right. I designed a transparent PNG image by paint 3D and it worked. |
