30 floors skyscraper on visu - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: 30 floors skyscraper on visu (/showthread.php?tid=6336) |
30 floors skyscraper on visu - gdimaria - 06.03.2026 I need to create thirty pages, one for each floor of a skyscraper. I'd like to use a vertical slider (1-30) in the homepage, next to the image and then, based on the floor selected, jump to the relative page (/apps/data/visu/#xxx). How could I do it? Peppe RE: 30 floors skyscraper on visu - Daniel - 06.03.2026 You can do it like this, just create more ifs and put corect plan IDs Code: localbus.listen('object', '0/0/1', (value) => {
if (value==0) {
Visu.showPlan(7);
else if (value==1) {
Visu.showPlan(17);
else {
Visu.showPlan(13);
});RE: 30 floors skyscraper on visu - gdimaria - 06.03.2026 (06.03.2026, 15:30)Daniel Wrote: You can do it like this, just create more ifs and put corect plan IDs That's perfect, but I would like to add a confirmation: showPlan not just when the object has a certain value, but when another object (boolean) is pressed. RE: 30 floors skyscraper on visu - Erwin van der Zwart - 06.03.2026 That can be done with an extra virtual object, press ok binary object with event based script and write the slider value to the virtual object that is attached to the grp.listen function. RE: 30 floors skyscraper on visu - gdimaria - 07.03.2026 (06.03.2026, 20:29)Erwin van der Zwart Wrote: That can be done with an extra virtual object, press ok binary object with event based script and write the slider value to the virtual object that is attached to the grp.listen function. ok, thanks another question: is there a way in VISU to export a SINGLE plan, layout, widjet etc. so I can use them importing in a new project? RE: 30 floors skyscraper on visu - Daniel - 08.03.2026 In new upcoming version there will be option to export/import custom widgets but not plans/layouts yet. RE: 30 floors skyscraper on visu - admin - 09.03.2026 Any solution relying on objects will only work for a single user, not if multiple users are connected to Visu at the same time. Using a vertical slider for selecting plans might look nice but it's not a user-friendly solution. Using 3 custom widgets with plan links grouped by 10 per widget will be much easier and faster to navigate. |
