mosaic 3.0 - Printable Version
+--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24)
+--- Thread: mosaic 3.0 (/showthread.php?tid=6338)
mosaic 3.0 - Pedro - 08.03.2026
I would like to know if you have any pre-designed template for a flat/apartment (for example for lights, blinds, climate, etc.) that can be used with LogicMachine.
Is there any ready-made project or example configuration that we could use as a starting point?
RE: mosaic 3.0 - admin - 11.03.2026
Which Visualization are you using? If you are using Mosaic as the topic name says you simply add widgets and that's it. But the recommended approach is to use new Visu. You can switch to Tile view only mode which will be very similar to Mosaic.
