Syslog differences between Resident and Event Scripts - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Syslog differences between Resident and Event Scripts (/showthread.php?tid=6349) |
Syslog differences between Resident and Event Scripts - BarryFromBondi - 12.03.2026 I have the exact same Syslog set up in my Resident and Event Scripts - the Resident Scripts Syslog works, however the Event scripts doesnt The syslog set up that works in Resident is local socket = require("socket") ------------------------------------------------- -- SYSLOG CONFIG ------------------------------------------------- local SYSLOG_HOST = "192.168.1.51" local SYSLOG_PORT = 1514 local HOSTNAME = "logicmachine" local APPNAME = "solar-master" local LOG_INTERVAL = 60 -- seconds ------------------------------------------------- -- PERSISTENT UDP SOCKET ------------------------------------------------- storage.syslog_socket = storage.syslog_socket or socket.udp() local udp = storage.syslog_socket udp:settimeout(0) ------------------------------------------------- -- RFC5424 TIMESTAMP ------------------------------------------------- local function rfc5424_time() local now = os.time() local utc = os.time(os.date("!*t", now)) local offset = os.difftime(now, utc) local sign = "+" if offset < 0 then sign = "-" end offset = math.abs(offset) local hours = math.floor(offset / 3600) local mins = math.floor((offset % 3600) / 60) return os.date("%Y-%m-%dT%H:%M:%S") .. string.format("%s%02d:%02d", sign, hours, mins) end ------------------------------------------------- -- SYSLOG SENDER ------------------------------------------------- local function slog(fields) local timestamp = rfc5424_time() local msg = "<14>1 "..timestamp.." "..HOSTNAME.." "..APPNAME.." - - - "..fields udp:sendto(msg, SYSLOG_HOST, SYSLOG_PORT) end What needs to change for an Event Script to behave the same way and allow for logging to an external syslog server? Thanks RE: Syslog differences between Resident and Event Scripts - admin - 13.03.2026 Sharing socket between scripts is not possible. You can simply create a new socket for each slog() call. Add the following code to Common functions to make slog() function available for all scripts. Code: local function rfc5424_time()
local sign = "+"
local SYSLOG_HOST = "192.168.0.2"
local sock = require('socket').udp()
sock:sendto(msg, SYSLOG_HOST, SYSLOG_PORT)
sock:close()
end |
