new Visu Project from an old visualization - Printable Version
+--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24)
+--- Thread: new Visu Project from an old visualization (/showthread.php?tid=6355)
new Visu Project from an old visualization - gdimaria - 17.03.2026
HI,
A customer asked me to redo the supervision I've done years ago with "scada-vis" with the new Visu.
So I updated the firmware, worked on Visu, and finally completely deleted the old "scada-vis" project.
I backed up the new project (both the entire project and just the Visu) and then reset the machine to factory settings.
So I restored the new Visu Project and now it ok but now I see the old visu app, empty!
I tried exporting objects, views, and scripts separately and then resetting them to factory defaults and the to restore all of it. The old view disappears, but I'm missing icons and objects in new Visu.
Is there a way to completely remove references to the old view?
I
RE: new Visu Project from an old visualization - Daniel - 17.03.2026
https://logicmachine.net/manuals/lm-20251201.pdf
page 43
RE: new Visu Project from an old visualization - gdimaria - 17.03.2026
ok, thanks.
Another question: the customer is used to the classic LM app on ipad and tablet at home.
Can he still keep using it under is LAN and use "LM Home" only for remote access on smartphone?
Don't get the reasons for doing so but yes. LM Home will automatically switch between local and cloud connection depend if you are on the same network as LM or not.
(17.03.2026, 14:08)Daniel Wrote: Don't get the reasons for doing so but yes. LM Home will automatically switch between local and cloud connection depend if you are on the same network as LM or not.
uh, ok...in that case they will use only LM home
