Issues with KNX/IP and BACnet/IP when using 170.x.x.x network range - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Issues with KNX/IP and BACnet/IP when using 170.x.x.x network range (/showthread.php?tid=6356) |
Issues with KNX/IP and BACnet/IP when using 170.x.x.x network range - Alberto.ricof - 18.03.2026 Hi, I'm facing a strange issue with a LogicMachine in a project. Current setup: LAN network configured as: 170.25.18.x Web access to the LM works fine The issue: ETS cannot connect (error reading device description on port 3671, ping works) KNXnet/IP tunneling is not working BACnet/IP export is also not working However: Web server works normally IP connectivity is OK (ping works) What I have already tried: Reboot LogicMachine Reboot router Factory reset of the LogicMachine (no change in behavior) Configured ETS interface properly My question is: * Could using a public IP range like 170.x.x.x cause issues with KNX/IP (UDP/multicast) and BACnet/IP? * Could the LogicMachine or router handle this differently compared to private networks (192.168.x.x / 10.x.x.x)? Has anyone experienced something similar? Thanks. RE: Issues with KNX/IP and BACnet/IP when using 170.x.x.x network range - Daniel - 18.03.2026 Yes LM is blocking KNX IP and BAcnet from public IPs due to security as they have zero protections, anyone can access your site and do anything. |
