DMX lighting control - Printable Version
+--- Thread: DMX lighting control (/showthread.php?tid=6374)
DMX lighting control - phongvucba - 31.03.2026
Hi everyone! I have a project that uses this kit and I want to integrate it with my LM. Can I connect it?
It's this kit; can I connect it to the LM via the RS485 port?
Thank so much everyone! Smile
RE: DMX lighting control ! - admin - 31.03.2026
What exactly do you want to integrate? Do you need to control DMX lights from LM? In this case you should use LAN connection instead of RS-485. Use this example that directly maps group addresses to DMX channels: https://forum.logicmachine.net/showthread.php?tid=1391&pid=8511#pid8511
RE: DMX lighting control ! - phongvucba - 31.03.2026
(31.03.2026, 08:07)admin Wrote: What exactly do you want to integrate? Do you need to control DMX lights from LM? In this case you should use LAN connection instead of RS-485. Use this example that directly maps group addresses to DMX channels: https://forum.logicmachine.net/showthread.php?tid=1391&pid=8511#pid8511
That's right! I want to control DMX lights from an LM. Can you show me how to connect via LAN? And why should I choose LAN instead of RS485?
Because I saw an example of connecting via RS485 here:
https://kb.logicmachine.net/integration/dmx-lighting/
Thank so much !
Yes, you can connect LM directly to DMX-512 bus via RS-485. LAN method is preferable because the script will consume less CPU resources especially when many lights are connected. Your Art-Net converter should have some tool for IP and DMX port configuration. Check the device manual.
RE: DMX lighting control ! - Sral1987 - 02.04.2026
Thank so much !
This should help here:
Your device is an ArtNET to DMX Converter.
