Realtime Clock - Printable Version
+--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24)
+--- Thread: Realtime Clock (/showthread.php?tid=6376)
Realtime Clock - KoBra - 01.04.2026
Is it possible to display the RTC inside the LM in Visu?
RE: Realtime Clock - admin - 02.04.2026
Custom JavaScript example that adds current time near the close button. Header option must be enabled in General settings for this to work in Plan view.
const el = document.querySelector('.navbar > .container-fluid > div:last-child') if (el) {   const span = document.createElement('span')   span.classList.add('me-2', 'd-flex', 'align-items-center')   el.prepend(span)      const update = () => {     const date = new Date()     span.textContent = date.toLocaleTimeString()   }      setInterval(update, 500)   update() }
RE: Visu bugs - Novodk - 09.04.2026
After implementing the time via JS the main title is shifted to the left, can this be resolved?
[Image: tlEFY0Z.png]
RE: Realtime Clock - admin - 09.04.2026
Try this:
const el = document.querySelector('.navbar > .container-fluid > div:last-child') if (el) {   const span = document.createElement('span')   el.classList.add('position-relative')   span.classList.add('position-absolute', 'top-0', 'bottom-0', 'd-flex', 'align-items-center')   span.style.right = '120%'   el.prepend(span)      const update = () => {     const date = new Date()     span.textContent = date.toLocaleTimeString()   }      setInterval(update, 500)   update() }
RE: Realtime Clock - AlexLV - 09.04.2026
is possible provide Custom JavaScript for Tile View also?
Alex
RE: Realtime Clock - Novodk - 09.04.2026
(09.04.2026, 17:28)AlexLV Wrote: Hi,
Alex
It works in Tile view as well.
If you want 24 hour format and date here is an example
const el = document.querySelector('.navbar > .container-fluid > div:last-child') if (el) {   const span = document.createElement('span')   el.classList.add('position-relative')   span.classList.add('position-absolute', 'top-0', 'bottom-0', 'd-flex', 'align-items-center')   span.style.right = '130%'   el.prepend(span)   const update = () => {   const date = new Date()   span.textContent = date.toLocaleString('en-GB', {     day: '2-digit',     month: '2-digit',     year: 'numeric',     hour: '2-digit',     minute: '2-digit',     second: '2-digit',     hour12: false   }).replace(',', '') }     setInterval(update, 500)   update() }
RE: Realtime Clock - admin - 10.04.2026
If you only want time in 24H format without seconds:
span.textContent = date.toTimeString().substring(0, 5)
RE: Realtime Clock - cekca - 16.04.2026
with dark theme the clock don't switch to white color
RE: Realtime Clock - admin - 17.04.2026
Add this before line 6 (span.style.right = '120%'):
span.style.color = 'var(--visu-header-text-color)'
RE: Realtime Clock - AlexLV - 17.04.2026
I use tile view ONLY and this idea with clock not working for me.
Alex
It will only work in user view but not admin view.
Have you placed the code into the right place? It should be added to Visu admin > Top right menu (⋮) > Custom JavaScript.
Yes, code is in right place, but I checked with admin.
Now will check in user view
RE: Realtime Clock - davidchispas - 08.06.2026
Hi, is it possible to display a KNX object on the opposite side? For example, the room temperature?
RE: Realtime Clock - admin - 08.06.2026
Use this:
const el2 = document.querySelector('.navbar > .container-fluid > div:first-child') const addr = '32/0/3' if (el2) {   const span = document.createElement('span')   el2.classList.add('position-relative')   span.classList.add('position-absolute', 'top-0', 'bottom-0', 'd-flex', 'align-items-center')   span.style.color = 'var(--visu-header-text-color)'   span.style.left = '120%'   el2.prepend(span)      localbus.listen('object', addr, (value) => span.textContent = `${value}°C`) }
RE: Realtime Clock - KoBra - 08.06.2026
(02.04.2026, 11:04)admin Wrote: Custom JavaScript example that adds current time near the close button. Header option must be enabled in General settings for this to work in Plan view.
Sorry i ment as a Widget not in the title bar.
RE: Realtime Clock - admin - 09.06.2026
Create a HTML widget. Put anything in the HTML input, the script below will replace it with date/time. Change widgetId to your actual widget ID.
const widgetId = 40 let interval Visu.on('widget-ready', widgetId, ({ widget }) => {   const el = widget.getEl()   el.classList.add('d-flex', 'align-items-center', 'justify-content-center')      const update = () => {     const date = new Date()     el.textContent = date.toLocaleString('en-GB', {       day: '2-digit',       month: '2-digit',       year: 'numeric',       hour: '2-digit',       minute: '2-digit',       second: '2-digit',       hour12: false     }).replace(',', '')   }      setInterval(update, 500)   update() }) Visu.on('widget-hide', widgetId, () => clearInterval(interval))
