Modbus TCP problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus TCP problem (/showthread.php?tid=6377) |
Modbus TCP problem - judgment - 01.04.2026 hello please help. It seams that LM do not initiate any modbus tcp read request to modbus slave device. Tested with modbus Poll all works fine. Tried firmware upgrade - same issue. any ideas? ![]() RE: Modbus TCP problem - admin - 02.04.2026 See if you can ping Modbus device IP address from System config > Status > Network utilities. RE: Modbus TCP problem - judgment - 02.04.2026 (02.04.2026, 10:39)admin Wrote: See if you can ping Modbus device IP address from System config > Status > Network utilities. hi tested - 4 packets transmitted, 0 packets received, 100% packet loss. Both, LM and other device i can access via http. Do you have a clue? RE: Modbus TCP problem - AEK - 03.04.2026 (02.04.2026, 19:00)judgment Wrote:(02.04.2026, 10:39)admin Wrote: See if you can ping Modbus device IP address from System config > Status > Network utilities. what IP settings are on LM and on your Modbus tcp device (IP, Netmask, Gateway) RE: Modbus TCP problem - judgment - 03.04.2026 (03.04.2026, 06:16)AEK Wrote:(02.04.2026, 19:00)judgment Wrote:(02.04.2026, 10:39)admin Wrote: See if you can ping Modbus device IP address from System config > Status > Network utilities. LM: 192.168.1.3, 255.255.255.0, 192.168.1.1 Modbus device : 192.168.1.4, 255.255.255.0, 192.168.1.1 Same subnet. Both devices are reachable from my PC, and ping works 100%. RE: Modbus TCP problem - admin - 03.04.2026 How are both devices connected? Switch or router? Maybe there is a firewall or port isolation is enabled. |
