YABE - Printable Version
+--- Thread: YABE (/showthread.php?tid=6407)
YABE - ALEJANDRO - 28.04.2026
Good afternoon,
I have created a VPN through which I access four logic machines:
-192.168.0.11
-192.168.0.12
-192.168.0.13
-192.168.0.14
The VPN IP address on my computer is 10.8.0.3. The four logic machines are configured to deliver data via BACnet IP address, each separately.
I need to connect remotely to the logic machines through the VPN using Yabe to verify that the BACnet connection is working correctly and is of good quality. However, I am unable to access the IP addresses of the logic machines or the objects that each logic machine exports via BACnet IP address.
RE: YABE - admin - 29.04.2026
BACnet device discovery uses broadcast communication which is limited to a single network. It won't work over VPN since your VPN IP belongs to a different network.
RE: YABE - ALEJANDRO - 30.04.2026
Is there a way to remotely check the BACNET IP communication? I don't know if it's through CMD.
RE: YABE - admin - 30.04.2026
You either must be in the same sub-network as LMs (192.168.0.x) or you must use BACnet router (BBMD). There's no other way.
Please stop asking the same question multiple times. You won't get a different answer.
