Issue after upgrade to 2025.12 - Printable Version
+--- Thread: Issue after upgrade to 2025.12 (/showthread.php?tid=6424)
Issue after upgrade to 2025.12 - tuxtof - 14.05.2026
I just upgraded my LM5P2 to the last firmware version.
Following that, my object tab is now completely empty.
I tried to restore the pre upgrade backup , but unfortunately it didn't change anything.
The other tabs seem OK, like scripting or logs.
Does anyone have an idea?
RE: Issue after upgrade to 2025.12 - Daniel - 14.05.2026
Send your backup to PM, the old one and the current. Use some online storage for this.
RE: Issue after upgrade to 2025.12 - tuxtof - 14.05.2026
looks like i have the issue only with Safari who is my main browser and who was working perfectly with my old logic firmware
in Chrome in see all the objects
Did you try to clear browser cache?
clearing the browser cache don't fix anything
but i found the solution, i add to logout /login back from the machine
usse fixed :-D
From which version did you update?
i'm not sure , something around end of 2022
how i can verify ?
No need, this was due to authenticaton change in 2024, it will be fine now.
thanks a lot
