R6HC - Printable Version
+--- Forum: CANx (https://forum.logicmachine.net/forumdisplay.php?fid=23)
+--- Thread: R6HC (/showthread.php?tid=6426)
R6HC - KoBra - 15.05.2026
I am trying to control a R6HC but as soon as i give a 1 to a relay it goes on and off the next second.
I use Relay and status, they both change in LM but go back. If i directly write value in the CANX interface it stays on so it seems there is something i am missing between LM and CANX
RE: R6HC - RomansP - 15.05.2026
What load have you connected to relay - how many ampers and what type of load - is it electric motor or something else?
RE: R6HC - KoBra - 15.05.2026
nothing yet at the moment
will be small pumps
Can you perform a hard reset for R6HC (by pressing programming button for more than 4 seconds), after reset check the working of relay. Also check if there are any scripts that can control the boolean object that controls the relay.
