reset SL IP address - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: reset SL IP address (/showthread.php?tid=6449) |
reset SL IP address - khalil - 03.06.2026 Hello Dears, How to reset SL IP address, I try press 10s on reset (I have old HW, reset in the back) then I can ping the default IP but cannot access SL webpage. then when press it again prifely I think it restore the original IP. Is it possible to reset the IP without deleting the project? RE: reset SL IP address - Daniel - 03.06.2026 10 sec long press on reset button will change the IP to default one but temporarily(reset LED will flash red), after a reboot it will go back to normal. You should be able to login to it and change the IP. If you can't access the page but you can ping it it sound like some file corruption. RE: reset SL IP address - khalil - 03.06.2026 DO I need to type any thing after IP like /apps or some thing ? RE: reset SL IP address - Daniel - 03.06.2026 No but you can try accessing directly system 192.168.0.10/flashsys |
