Rolling PIN Code - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Rolling PIN Code (/showthread.php?tid=6459) |
Rolling PIN Code - KoBra - 09.06.2026 Would it be possible to load the PIN code from an object instead of set it fixed? I have a location (Sports Center) where they have a changing code for the door and want to use the same code for the locked screens in visu. RE: Rolling PIN Code - admin - 10.06.2026 Do you mean plan or object pincode? RE: Rolling PIN Code - KoBra - 10.06.2026 (10.06.2026, 08:00)admin Wrote: Do you mean plan or object pincode? Both if possible RE: Rolling PIN Code - admin - 10.06.2026 Use the following functions to set plan/widget pin code. For widget you need specify both plan ID that contains the widget and the widget ID. Plan ID / widget ID can be found in the window title when editing. Important: pin code value must be a string. New pin code must have the same length as the previous. Code: function setplanpin(planid, pincode)
local json = require('json')
local structure = storage.exec('hget', 'app:visu:main', 'structure')
local function setpin(items)
for _, item in ipairs(items) do
if item.id == planid then
item.pincode = pincode
return
if type(item.children) == 'table' then
setpin(item.children)
structure = json.decode(structure)
setpin(structure)
local data = json.encode(structure)
storage.exec('hset', 'app:visu:main', 'structure', data)
setplanpin(41, '123456')Code: function setwidgetpin(planid, widgetid, pincode)
local key = 'widgets:' .. planid
local widgets = storage.exec('hget', 'app:visu:main', key)
widgets = json.decode(widgets)
for _, widget in ipairs(widgets) do
if widget.id == widgetid then
widget.pincode = pincode
break
local data = json.encode(widgets)
storage.exec('hset', 'app:visu:main', key, data)
setwidgetpin(41, 42, '123456')RE: Rolling PIN Code - KoBra - 10.06.2026 (10.06.2026, 08:43)admin Wrote: Use the following functions to set plan/widget pin code. For widget you need specify both plan ID that contains the widget and the widget ID. Plan ID / widget ID can be found in the window title when editing. Could i load the PIN from a 250byte string object? In this way i could write the PIN to the datapoint when i load it from the PIN Generator at the tennis federation (in this case) RE: Rolling PIN Code - Daniel - 10.06.2026 Its a script, you can just do it like that Code: value = event.getvalue()
if #value == 6 then
setplanpin(41, value)
alert('wrong pin length: ' .. tostring(#value))
end |
