curl to post value to TRMNL api - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: curl to post value to TRMNL api (/showthread.php?tid=6463) |
curl to post value to TRMNL api - Pierre - 11.06.2026 Hello, I want to send data to TRMNL server this curl command is ok : curl "https://trmnl.com/api/custom_plugins/xxxxxxxxxxxxxxxxxxxxxxxxxxx\ -H "Content-Type: application/json" \ -d '{"merge_variables": {"text":"Test", "author": "Pierre"}}' \ -X POST but my lua code don't work: Code: -- Load modules
https = require('ssl.https')
ltn12 = require('ltn12')
json = require('json')
body ='{"merge_variables": {"text":"Test", "author": "Pierre"}}'
resp = {}
body = json.encode(Body)
res, code, headers = https.request({
url = 'https://trmnl.com/api/custom_plugins/xxxxxxxxxxxxxxxxxxxxxxxxxxx',
method = 'POST',
source = ltn12.source.string(body),
sink = ltn12.sink.table(resp),
headers = {
['Content-Type'] = 'application/json',
['Content-Length'] = #body
-- handle feedback
resp = table.concat(resp)
resp = json.pdecode(resp)
log(respi have this error: Must be nested inside a merge_variables payload object could you can help me please. RE: curl to post value to TRMNL api - admin - 11.06.2026 Try this: Code: http = require('socket.http')
body = json.encode({
merge_variables = {
text = 'Test',
author = 'Pierre',
resp, code, headers = http.request({
url = url,
method = 'POST',
body = body,
headers = {
log(resp)RE: curl to post value to TRMNL api - Pierre - 11.06.2026 perfect thanks a lot |
