Tile view layout broken (large empty gaps) for thermostat widgets on mobile Safari — - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Tile view layout broken (large empty gaps) for thermostat widgets on mobile Safari — (/showthread.php?tid=6491) |
Tile view layout broken (large empty gaps) for thermostat widgets on mobile Safari — - andreaemanuelli - 30.06.2026 hi everyone Firmware: LM5p2-KCDZ, 20251204 Visu version: new Visu (2025.11) Browser: Safari on iOS (also reproduced via LM Home app, same engine) ISSUE A Category containing 7 native "thermostat" type widgets (tile_width=2, tile_height=2 each) renders with large empty vertical gaps between rows on iPhone, both in portrait and on first load. Widgets are present in the DOM (confirmed via remote Web Inspector — all 7 elements have display:block, visibility:visible, correct getBoundingClientRect()), but visually appear scattered with huge blank spaces between them. The same Category with simple "switch" type widgets (lights, in the same Visu, same device) renders perfectly with no gaps. WORKAROUND FOUND Rotating the device screen once (portrait -> landscape -> portrait, or just to landscape) immediately fixes the layout — all widgets snap into a correct, gap-free grid. DIAGNOSIS This strongly suggests a Muuri grid layout calculation race condition: the thermostat widget's internal SVG (circular arc, +/- buttons) takes longer to reach final rendered dimensions than a simple switch icon. If Muuri's initial layout() call measures widget dimensions before the SVG has settled, it computes wrong absolute positions (translateX/ translateY) for those items, leaving gaps. A manual resize event (screen rotation) forces Muuri to recalculate using final dimensions. ATTEMPTED WORKAROUND (did not work) Tried dispatching window.dispatchEvent(new Event('resize')) via custom JS at multiple delays after page load (600ms/1200ms/2000ms/ 3500ms) to replicate the rotation effect. This did NOT fix the issue — suggesting Muuri's internal layout recalculation is not triggered by the generic window resize event, but by something else (ResizeObserver on the container, or an internal viewport-change handler specific to orientation change). QUESTIONS 1. Is this a known issue with the thermostat widget (or any widget with internal SVG) in tile view on narrow viewports? 2. Is there a way to programmatically trigger Muuri's layout() / refreshItems() from custom JS, since the Muuri instance isn't exposed on window? 3. Is there a recommended fix (CSS containment, explicit width/height constraints, etc.) to prevent this race condition? Happy to share screenshots, exported widget JSON and console output if useful for reproduction. Ctrl+F5 already tried, no effect (this isn't a cache issue — confirmed via fresh hard reload). RE: Tile view layout broken (large empty gaps) for thermostat widgets on mobile Safari — - admin - 30.06.2026 Which iOS version do you have? Please share Visu project backup. RE: Tile view layout broken (large empty gaps) for thermostat widgets on mobile Safari — - andreaemanuelli - 30.06.2026 (30.06.2026, 16:49)admin Wrote: Which iOS version do you have? Please share Visu project backup. iOS 26.5 RE: Tile view layout broken (large empty gaps) for thermostat widgets on mobile Safari — - admin - 01.07.2026 There is something wrong with your custom JavaScript. Without it the thermostat widgets are displayed correctly. |
