CANx DALI - setting the default color temperature - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: CANx DALI - setting the default color temperature (/showthread.php?tid=6493) |
CANx DALI - setting the default color temperature - achang - 01.07.2026 Hi I am currently using the CANx DALI gateway to control my lighting. I have a device that can change the color temperature using DT8, and I want to set this device's color temperature at a specific value at all times (i.e 3000K) However, every time the power goes off and turns back on again, the color temperature goes back to its default value. I found this parameter configuration where I can set the power on level. Would it be possible to add a parameter for the color temperature upon power on as well? RE: CANx DALI - setting the default color temperature - admin - 01.07.2026 Do you have the latest app version installed? |
