Unable to use the "data16" data type in Zigbee. - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Unable to use the "data16" data type in Zigbee. (/showthread.php?tid=6514) |
Unable to use the "data16" data type in Zigbee. - Samuel - 20.07.2026 Hello, Device: LM5P2-KDCZ I'm unable to use the "data16" (0x09) data type in a Lua script. I'm trying to trigger a Zigbee device using this event-based script. While running the script, I monitor all messages sent to the device using Wireshark. With this script, I don't see any messages being sent, and I get a "no response" error in the LogicMachine logs. If I change the data type to "uint16", for example, and run the script again, I can see that a message is sent to the device with Wireshark. However, it does not trigger the expected action, which is understandable since the data type is different. Code: local zb = require('applibs.zigbee')
local address = '0004740001248162'
local manufcode = 4129
local mode = event.getvalue()
local res, err = zb.cmdsync('setrawattribute', address, 64513, 0, mode, 'data16', manufcode)
if not res then
log('Writting error on contactor (' .. address .. '): ' .. tostring(err))
log('Contactor mode: ' .. tostring(mode))
endQuote:Log : Here, you will find a capture of a message sent using another Zigbee tool. This is the message I would like to send using this script. Does anyone know how to send a command with the "data16" data type from a Lua script? If some Zigbee Cluster Library (ZCL) data types are not supported by LogicMachine, is there any documentation available listing the supported data types? RE: Unable to use the "data16" data type in Zigbee. - admin - 20.07.2026 data16 must sent as a byte array. Try this, you might need to swap b1 and b2 if the byte order is incorrect: Code: local mode = event.getvalue()
local b1 = bit.band(bit.rshift(mode, 8), 0xFF)
local b2 = bit.band(mode, 0xFF)
local data = { b1, b2 }
local res, err = zb.cmdsync('setrawattribute', address, 64513, 0, data, 'data16', manufcode) |
