localbus javascript session expiration - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: localbus javascript session expiration (/showthread.php?tid=6531) |
localbus javascript session expiration - antlomb - 16.08.2026 Hello, I tried to find an answer but didn't find it. I'm writing some web pages to put in the user folder. The pages uses the localbus library with a newly created "dashboard" user. I succeeded in connecting the web pages to the localbus acalling the login page and authenticating with the new user. I correctly get notifications of events. I would like to understand how keep the session valid without expiration. I see there is a cookie expiration in N days, is it possible to disable the expiration of the cookies so that the session from the tablet I'm using to the server will be kept open forever ? Or is there a login api call which the page can periodically call to refresh the session ? I would not like to show the user the default login page when session expires. Thanks for the help you could give to solve this issue Best regards Antonio RE: localbus javascript session expiration - Daniel - 17.08.2026 You can extend the expiration time in user access settings but you cannot disable it. RE: localbus javascript session expiration - antlomb - 17.08.2026 So , if I understand well, this is true also for the scada-vis (old visu) ? A tablet which loads a page must authenticate and the session is supposed to expires ? No way to setup a UI which does not require maintenance ? Thank you Antonio RE: localbus javascript session expiration - Daniel - 17.08.2026 Yes but access token is refreshed automatically, it will only expiry if not used at all. |
