Rename group addresses - Printable Version
+--- Thread: Rename group addresses (/showthread.php?tid=6533)
Rename group addresses - davidchispas - 19.08.2026
I need to edit the names of the group addresses in bulk. For example, from group 1/1:
1/1/1 -> LIGHTING - ON/OFF - L01
1/1/2 -> LIGHTING - ON/OFF - L02
and so on...
1/1/100 -> LIGHTING - ON/OFF - L100
Only the object name needs to be changed, without modifying labels or data types.
RE: Rename group addresses - Daniel - 19.08.2026
Do you want to just set names of your object to the rule defined above or modify them?
RE: Rename group addresses - davidchispas - 19.08.2026
(19.08.2026, 13:08)Daniel Wrote: Do you want to just set names of your object to the rule defined above or modify them?
I want to set the names from scratch using the defined rule (ILUMINACION - ON/OFF - L01 up to L100) based strictly on their Group Addresses.
My object database is currently inconsistent:
Some objects have old, different names.
Some objects have no name at all (blank/empty).
Run this script once
-- Bulk rename: 1/1/1 → LIGHTING - ON/OFF - L01 ... 1/1/100 → LIGHTING - ON/OFF - L100 for i = 1, 100 do   local addr  = string.format('1/1/%d', i)   local name  = string.format('LIGHTING - ON/OFF - L%02d', i)   -- grp.create overwrites an existing object's name without touching   -- its datatype, tags, comment, or value — when you pass only   -- address + name + forcename=true.   local ok, err = grp.create({     address   = addr,     name      = name,     forcename = true,   -- replace the name even if the object already exists   })   if ok then     log(string.format('Renamed %s → "%s"', addr, name))   else     log(string.format('SKIP %s (does not exist or error: %s)', addr, tostring(err)))   end end log('Bulk rename complete.')
