Logic Machine cloud - Printable Version
+--- Thread: Logic Machine cloud (/showthread.php?tid=6536)
Logic Machine cloud - Elsam - 26.08.2026
Hi, can i somehow disable function "Connecting to local LM" when i open app LM Home? I always need to connect thogh cloud even if Im on same site with local LM. ThanksĀ
Always when I open LM Home and im connected to the local wifi, i get message "Connecting to LogicMachine"..
Adding screenshots
RE: Logic Machine cloud - Daniel - 26.08.2026
You can disable the service by ruining the script once:
require('uci') uci.set('genohm-scada', 'core', 'hideservice', 1) uci.commit('genohm-scada') os.execute('/etc/init.d/avahi-daemon restart')
RE: Logic Machine cloud - Elsam - 26.08.2026
(26.08.2026, 07:25)Daniel Wrote: You can disable the service by ruining the script once:
Thanks!
Hi again, I've tried to do it by "event" script but still didnt work, later, i tried to write whole code to init script - i rebooted lm and then i've erased script, still didnt work and app kept connecting me to local lm. then i tried also resident, after first trigger i deleted it and still kept connecting me..
Long press on LM home icon, go to settings and remove LM.
(26.08.2026, 13:22)Daniel Wrote: Long press on LM home icon, go to settings and remove LM.
Thanks, now it works Smile
