Kamailio 3.3.7 on LM5M3: can the package be rebuilt? (branch limit 12, no dialog) - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Kamailio 3.3.7 on LM5M3: can the package be rebuilt? (branch limit 12, no dialog) (/showthread.php?tid=6545) |
Kamailio 3.3.7 on LM5M3: can the package be rebuilt? (branch limit 12, no dialog) - krymsan - 09.09.2026 Hello, I am using the Kamailio SIP registrar described in kb.logicmachine.net/integration/sip-server/ on an LM5M3. The device tree reports "i.MX6UL LM5M3", ARMv7 Processor rev 5 (v7l), with genohm-scada 20251204. I installed it with the official resident-script method for the i.MX6 target: - kamailio3 3.3.7-1_imx6, plus the maxfwd, usrloc, registrar, rr, sl and tm modules - your default kamailio.cfg, unmodified First, it works well and I want to be clear about that. With no configuration changes I get multiple contacts registered against a single AoR, parallel forking to all of them, first-answer-wins with CANCEL to the losing branches, and RTP flowing directly between the endpoints - including between different subnets - since no media relay module is loaded. This is exactly the behaviour I need from a registrar for door-entry intercoms. I have run into three limits that all appear to need a rebuild rather than a configuration change, so my main question is simply: is a rebuilt package for the i.MX6 target something that can be provided? If not, the individual items below are moot. 1. BRANCH LIMIT OF 12 I registered 15 contacts against one AoR. All 15 registered successfully, but an incoming call forked to only 12 of them. I repeated the test and got 12 again, with a different subset of 12 each time. The log shows: ERROR: <core> [dset.c:306]: append_branch(): max nr of branches exceeded ERROR: registrar [lookup.c:298]: lookup(): failed to append a branch Since this is MAX_BRANCHES in the core rather than a module parameter, I cannot raise it from kamailio.cfg. I need at least 16 branches on a single AoR. Could the package be rebuilt with a larger MAX_BRANCHES, or with the limit exposed as a core parameter? 2. DIALOG MODULE It is not in the package. I looked for a kamailio3-mod-dialog .ipk at the distribution path, using the same naming pattern as the six modules that are published, and got 404. Same result for auth, auth_db, xlog, textops and nathelper, while all six published modules return 200. Without dialog there is nothing to clean up a session left behind when an endpoint disappears without sending BYE. Device-side call timers cover some of this, but not the case where only one side is gone. Is adding this module possible? 3. AUTH / AUTH_DB Also absent, so any device can register with any credentials. This is fine on a test bench but not something I can leave in place. 4. KAMAILIO VERSION 3.3.7 is from 2013 and no longer receives security fixes. Is a current branch (5.x or 6.x) for i.MX6 on the roadmap? I understand the configuration syntax differs and that this is the largest of the four requests. ONE MORE THING THAT MADE DIAGNOSIS HARDER There is no mi_fifo or kamctl, so I have no way to inspect the location table and see which devices are currently registered. If there is another way to read usrloc on the LM, I would be glad to hear it. I am happy to test any package and report results back here.
RE: Kamailio 3.3.7 on LM5M3: can the package be rebuilt? (branch limit 12, no dialog) - admin - 09.09.2026 SIP server on LM is meant for very small use cases like door phone integration. We don't have plans to provide a newer package version as it is very rarely used. You should install a separate device to handle SIP communication if you need a more complex configuration. |
