Widget Centering | VISU - Printable Version
+--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24)
+--- Thread: Widget Centering | VISU (/showthread.php?tid=6567)
Widget Centering | VISU - _BG_ - 29.09.2026
I have a question regarding New Visu.
The visualisation will be used mainly on a mobile phone (Tile view only).
Is it possible to center the widgets on the screen, or make them automatically scale to the phone’s screen width?
Custom widget size:320x430, 3x4
Switch widget size: 3x1
Or I just need to add some CSS or JS to achieve this?
I also have a question regarding “Tile view width” in Admin Visu. Does this parameter have any impact on the final appearance of the application?
Thanks in advance!
BG
RE: Widget Centering | VISU - Daniel - 29.09.2026
In General Settings you can define tile width and then tile view on mobile will stay always on the seize selected. The widget you use is 3 tiles.
RE: Widget Centering | VISU - _BG_ - 29.09.2026
(29.09.2026, 14:07)Daniel Wrote: In General Settings you can define tile width and then tile view on mobile will stay always on the seize selected. The widget you use is 3 tiles.
In general settings I only have this...
Update Visu to latest version.
(29.09.2026, 14:15)Daniel Wrote: Update Visu to latest version.
It works!
Thank You!
