Aqara T2 E27 Zigbee support - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Aqara T2 E27 Zigbee support (/showthread.php?tid=6572) |
Aqara T2 E27 Zigbee support - johnuopini - 07.10.2026 Hi, does the Aqara LED Bulb T2 E27 work with the LogicMachine Zigbee gateway in Zigbee mode? I could not find it in the supported device list. Does it support on and off, dimming, colour temperature and RGB? If not, can support be added? Thanks. RE: Aqara T2 E27 Zigbee support - Daniel - 07.10.2026 If it is not on the list then you know the same as we do. If they fallowed zigbee standard then the basic control should work. RE: Aqara T2 E27 Zigbee support - johnuopini - 07.10.2026 Thanks Daniel. Zigbee2MQTT supports this bulb. Could its device definition help add support in LM? What device information or logs would you need from me? https://www.zigbee2mqtt.io/devices/T2_E27.html RE: Aqara T2 E27 Zigbee support - Daniel - 07.10.2026 Pair it and test it. Send device information form the app. RE: Aqara T2 E27 Zigbee support - johnuopini - 10.10.2026 Thanks Daniel. I paired the bulb. Here is the device information from the app. Is this enough to add a profile? Code: Manufacturer: Aqara
Model: lumi.light.agl003
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 21
Profile: 260
Input clusters
- AnalogInput (12)
Endpoint 1
Profile: 260
Input clusters
- Scenes (5)
- Groups (4)
- Identify (3)
- Basic (0)
- LightingColorCtrl (768)
- LevelCtrl (8)
- OnOff (6)
- HaElectricalMeasurement (2820)
- SeMetering (1794)
- ManuSpecificAqaraOpple (64704)
Output clusters
- Ota (25)
- Time (10)
Reported attributes
- analoginput: 0.00
- calclevel: 254
- level: 254
- onoff: true
- prevlevel: 254 |
