http string commands to LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: http string commands to LM (/showthread.php?tid=6580) |
http string commands to LM - Domoticatorino - 22.10.2026 Hi there, I have some problem to send http commands to LM. The string is the following and obviously I enable remote service: http://remote:password@ip-address/scada-remote?m=json&r=grp&fn=write&alias=0/0/54&value=true (to control 0/0/54). If I test it on a web browser sometime works and sometime LM login page appears without send command. Hence I cannot understand what is the difference. I try to send the http from an external device which it working properly for other HTTP strings but I cannot send string to LM. What do you suggest to check? Thanks. Regards. RE: http string commands to LM - admin - 22.10.2026 Do you have "Send Basic auth header" enabled in Remote services settings? If not then enable and try again. RE: http string commands to LM - Domoticatorino - 22.10.2026 (Yesterday, 11:56)admin Wrote: Do you have "Send Basic auth header" enabled in Remote services settings? If not then enable and try again. I do it and I try again later on. I keep you informed. In the meanwhile I have seen on web browser that web response is simply "true" and not OK 200. Is it normal? Thanks. BR RE: http string commands to LM - admin - 23.10.2026 "true" is what grp.write() returns when the write succeeded. "200 OK" is the first response header which is not shown by the browser. |
