SMS Problem on Reactor - Printable Version
+--- Thread: SMS Problem on Reactor (/showthread.php?tid=6592)
SMS Problem on Reactor - Frank68 - 09.11.2026
Good morning,
I am having an issue with SMS messages from the reactor. I have verified that the SIM card is working, as email functionality—which uses the same SIM—is operating correctly. I have also checked the SMS script, and everything appears to be in order.
There are no errors showing in the log.
Thank you very much.
RE: SMS Problem on Reactor - admin - 09.11.2026
Do you mean sending or receiving SMS messages? Add logging as suggested in this post: https://forum.logicmachine.net/showthread.php?tid=5403&pid=38043#pid38043
RE: SMS Problem on Reactor - Frank68 - 09.11.2026
(7 hours ago)admin Wrote: Do you mean sending or receiving SMS messages? Add logging as suggested in this post: https://forum.logicmachine.net/showthread.php?tid=5403&pid=38043#pid38043
Nothing appears in the log ?
Have you restarted the resident script after changing the user library? Anything in Alerts and Error logs?
(3 hours ago)admin Wrote: Have you restarted the resident script after changing the user library? Anything in Alerts and Error logs?
Yes, I’ve restarted the SMS resident  script, but there are no alerts or errors.
You should at least get "SMS handler init" and "SMS handler started" / "SMS USB init failed" alerts when the resident script starts. Do you get these alerts?
(2 hours ago)admin Wrote: You should at least get "SMS handler init" and "SMS handler started" / "SMS USB init failed" alerts when the resident script starts. Do you get these alerts?
nothing
nothing
Send your LM backup via PM.
(2 hours ago)admin Wrote: Send your LM backup via PM.
in PM is not possible to add file
Use some file sharing service like WeTransfer
Run this script once and post what you get in Logs tab:
res = io.readproc('ls /sys/class/tty') log(res)
