Different LM configuration - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Different LM configuration (/showthread.php?tid=6597) |
Different LM configuration - knxlm - 20.11.2026 Hi! I have some LM with last version firmware 20251204, but different configurations DALI.jpg has (DALI, EnOcean, 1-wire) noDALI.jpg has not these tabs (DALI, EnOcean, 1-wire) I don't know where I have to configure it. thanks RE: Different LM configuration - Daniel - 20.11.2026 It seems that you installed wrong firmware on it. What LM is it? Check the side label. RE: Different LM configuration - knxlm - 20.11.2026 First one is: Second one is: Maybe I confused when I installed firmware? Because two machines are physically the same. Can I reinstall the LM5 lite firmware in the first one? RE: Different LM configuration - Daniel - 20.11.2026 Software will not tell you the truth if you already used wrong firmware, check the side label. |
