logicmachine restart - Printable Version
+--- Thread: logicmachine restart (/showthread.php?tid=6602)
logicmachine restart - Frank68 - 25.11.2026
Good morning,
Is it possible to restart the Logic Machine using a schedulable script? If so, how does the retransmission of alarms—triggered by event tags—behave upon restart if the value remains constant?
Thank you very much.
RE: logicmachine restart - Daniel - 25.11.2026
You can use this in a Scheduled script just make sure you don't run it too often as if LM wont be able to boot before next reboot will happen then you will never be able to connect to LM again.
os.execute("reboot")
LM does not re-transmit anything on boot, unless it is set up in init script.
