Read/write file to LM5 connected USB - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Read/write file to LM5 connected USB (/showthread.php?tid=678) |
Read/write file to LM5 connected USB - Rodriguez - 16.03.2017 Hello, I am working with the logic machine 5 and I want to do a test of reading and writing files through a USB, but the example I find is focused on linux, does it work with windows? Or does it have a different syntax? Another question, this code - create usb mount directory The.execute ('mkdir -p / mnt / usb') - find first matching usb storage device Dev = io.readproc ('ls / dev / sd * 1 2> / dev / null'): match ('/ dev / sd% l1') - found it, mount If dev then The.execute ('mount' .. dev .. '/ mnt / usb') Alert ('[usb-mount] mounted% s', dev) - nothing found, local flash will be used Else Alert ('[usb-mount] no device found') End Hurt directly in the script or would relate to common functions? Thank you. RE: Read/write file to LM5 connected USB - buuuudzik - 16.03.2017 Here you have a script for mounting USB: Code: part = '/dev/sda1'
if io.exists(part) then
os.execute('mount ' .. part .. ' /mnt')
alert('mount ok')
alert('usb disk not found')
endAnd this is for writing and reading a file from USB: Code: path = '/mnt/'
status = io.exists(path)
io.writefile(path .. 'new.txt', 'This is my new file.')
result = io.readfile(path .. 'new.txt')
log(status, result)RE: Read/write file to LM5 connected USB - Rodriguez - 16.03.2017 You have been very helpful, thank you. RE: Read/write file to LM5 connected USB - buuuudzik - 16.03.2017 This is from admin
RE: Read/write file to LM5 connected USB - Shalltear - 29.03.2017 Hi, I was working with that code but it is not writing to me in memory, it is only printing the message in the registers (logs), but in memory it does not write anything to me, what could happen? RE: Read/write file to LM5 connected USB - admin - 30.03.2017 What kind of task are you trying to achieve? If you want to store some data externally then FTP or remote database is a much better solution than a USB drive which is not designed for 24/7 operation. RE: Read/write file to LM5 connected USB - Shalltear - 30.03.2017 Hi, what I want is to be able to write on an existing file from the logic machine, and also be able to read this, since I need to perform this task with USB at specific times. RE: Read/write file to LM5 connected USB - Rodriguez - 10.04.2017 Hi , a while ago I worked this example, I want to take it back, but it tells me that the connection is created but at the moment of writing in memory it does not, what error could I be presently presenting? RE: Read/write file to LM5 connected USB - admin - 11.04.2017 First, reboot your LM. Since you have tried different scripts your mount table is probably messed up. Second, make sure your flash drive is formatted as FAT or FAT32 (but not exFAT). Run this script once, then go to System Config > Status > System Status. In Partitions tab you should see that /dev/sda1 or similar is mounted under /mnt. Then you can use io.writefile('/mnt/myfile.txt', 'test') to write something onto USB drive. Code: devs = io.ls('/sys/class/block/')
table.sort(devs)
for _, dev in ipairs(devs) do
if dev:match('^sd%a%d$') then
part = dev
break
elseif not devn and dev:match('^sd%a$') then
devn = dev
part = part or devn
if part then
os.execute('umount -f /mnt 2>&-')
res, stat = io.readproc('mount /dev/' .. part .. ' /mnt 2>&1')
if stat == 0 then
alert('USB mount OK')
alert('USB mount failed: ' .. tostring(res))
alert('No valid USB devices found')
endRE: Read/write file to LM5 connected USB - Rodriguez - 12.04.2017 It worked! Thanks, I really was very helpful.
RE: Read/write file to LM5 connected USB - linux_sun - 05.05.2026 (30.03.2017, 06:50)admin Wrote: What kind of task are you trying to achieve? If you want to store some data externally then FTP or remote database is a much better solution than a USB drive which is not designed for 24/7 operation. That’s interesting—what would be the most appropriate approach for handling the storage and access of high-frequency data (for example, every 30 seconds)? Would it be better to rely on a remote database (such as InfluxDB or PostgreSQL) rather than solutions like FTP? RE: Read/write file to LM5 connected USB - Daniel - 05.05.2026 What is the task you try to solve? |
