Shutter command - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Shutter command (/showthread.php?tid=703) |
Shutter command - Domoticatorino - 27.03.2017 Hi, I would to simplify the shutter commands. In visualisation I have to use 3 icons for up, stop and down. As you can see is smartphone visualisation we have 3 lines per shutter. Could you suggest anything different please? Thanks. RE: Shutter command - Thomas - 28.03.2017 Dear LM, it would be great to have 3 button controller. Up - stop - down in one row which utilise two group objects. First for up/down, second for stop (short operation). Domoticatorino I use "position" instead of up/down (called Long operation in KNX) in touch visu. This solution takes only one row. Alternatively look if you can switch your shutter to up - stop - down - stop mode. Most of shutters support this mode. |
