KnxNet/IP - bug ? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: KnxNet/IP - bug ? (/showthread.php?tid=707) |
KnxNet/IP - bug ? - oyvindi - 29.03.2017 Hi, this is a few (low-level) questions about the KnxNet/IP implementation on Logic Machine 5. I too a look at UDP-packages in Wireshark while connecting to LM5 with ETS5, and found some anomalies. 1) In system settings -> KNX Settings, I specified that I want EIBNet/IP Tunnelling. However, LM5 keeps sending ROUTING_INDICATION packages ? 2) When doing a CONNECTIONSTATE_REQUEST, the CONNECTIONSTATE_RESPONSE should contain one of the status codes: E_NO_ERROR = 0x00, E_CONNECTION_ID = 0x21, E_DATA_CONNECTION = 0x26, E_KNX_CONNECTION = 0x27 However, LogicMachine replies with code 0x15, which is an unknown status. Output from WireShark: Request: Code: Frame 729: 58 bytes on wire (464 bits), 58 bytes captured (464 bits) on interface 0
Ethernet II, Src: Giga-Byt_28:b3:64 (fc:aa:14:28:b3:64), Dst: OpenrbCo_26 (00:1b:c5:00:10:26)
Internet Protocol Version 4, Src: 10.20.25.30, Dst: 10.20.25.123
User Datagram Protocol, Src Port: 52989, Dst Port: 3671
KNXnet/IP
Header
Header Length: 0x06
Protocol Version: 0x10
Service Type Identifier: CONNECTIONSTATE_REQUEST (0x0207)
Total Length: 16 octets
Body
Communication Channel ID: 1
reserved: 00
HPAI: Control endpoint
Structure Length: 8 octets
Host Protocol Code: IPV4_UDP (0x01)
IP Address: 10.20.25.30
IP Port: 52988
HEX:
0000 06 10 02 07 00 10 01 00 08 01 0a 14 19 1e ce fcResponse: Code: Frame 730: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Ethernet II, Src: OpenrbCo_26 (00:1b:c5:00:10:26), Dst: Giga-Byt_28:b3:64 (fc:aa:14:28:b3:64)
Internet Protocol Version 4, Src: 10.20.25.123, Dst: 10.20.25.30
User Datagram Protocol, Src Port: 3671, Dst Port: 52988
KNXnet/IP
Header
Header Length: 0x06
Service Type Identifier: CONNECTIONSTATE_RESPONSE (0x0208)
Total Length: 8 octets
Body
Status: Unknown (0x15)
HEX:
0000 06 10 02 08 00 08 01 15I am currently implementing a KnxNet/IP client, which is why I stumbled across these issues. RE: KnxNet/IP - bug ? - admin - 29.03.2017 1. It will always send telegrams to Routing if IP features are enabled 2. Looks like a bug, will fix 3. Are you connected to a KNX/TP gateway via Tunneling? RE: KnxNet/IP - bug ? - oyvindi - 29.03.2017 Yes, I am connected via Tunnelling. - Øyvind |
