KNX/TP alerts/errors - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: KNX/TP alerts/errors (/showthread.php?tid=744) |
KNX/TP alerts/errors - Bitver - 19.04.2017 I have strange errors and alert in LM4 latest firmware: Errors: KNX/TP: Transmitter Error (send 0 receive 1) KNX/TP: Temperature Warning Alerts: KNX/TP: Connected KNX/TP: Disconnected Source - system. Messages may repeat ~0-10 times a day. All works properly without any issues. What does this mean? RE: KNX/TP alerts/errors - bmodeco - 20.04.2017 Hi, I can confirm this - seeing this also on my LM5-PMU. Everything working fine. Best regards, Bart RE: KNX/TP alerts/errors - rocfusion - 21.04.2017 Hi, I second that confirmation. Have a LM4 doing this also. LM4 is connected on the main line with 4 other MDT bus couplers. Have replaced the bus couplers already. Thanks, Roger RE: KNX/TP alerts/errors - rocfusion - 16.04.2018 Hi, Does anyone have a solution for this, I have 2x LM4 that do this. What I have discovered is that this happens when I program with ETS more than 2 devices on the bus with the LM. Thanks, Roger RE: KNX/TP alerts/errors - mlaudren - 18.04.2018 Hi, Check out this topic: https://forum.logicmachine.net/showthread.php?tid=1261 It's the same issue. |
