Problem with 2 modbus devices - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Problem with 2 modbus devices (/showthread.php?tid=766) |
Problem with 2 modbus devices - Mirco - 02.05.2017 Hi guys, I have an HomeLYnk that read from a PLC that controls an UTA, and write into a PLC that controls pumps, heating and cooling. I used 2 profile: - the one that read from the UTA use TCP/IP and works perfectly; - the one that write some object (readed in the other profile) use RTU; When the object is updated by the read of the other profile, it is not written into the PLC of the pumps. If I update the value of the object manually, it is written correctly into the PLC. I bypassed this problem using script, but I would like to know if I've done something wrong Thanks! RE: Problem with 2 modbus devices - admin - 02.05.2017 It's not working for you because the modbus plugin ignores telegrams that are sent by itself, otherwise there's a high chance of having an infinite read/write loop. RE: Problem with 2 modbus devices - Igor68 - 02.05.2017 Hi, I have 3 ports of RS-485 on lm4 . How can I make RTU settings different for each port to use Modbus profiles? RE: Problem with 2 modbus devices - admin - 02.05.2017 Only one port can be used with mapper right now, other ports can be used via scripting. RE: Problem with 2 modbus devices - Igor68 - 03.05.2017 Thank you, it would be good to work with the help of profiles, it is very convenient |
